Manco 710-E Chain Help
Medrace
I am having a problem with my chain. I recently purchased this go kart and installed a new jackshaft, sprocket, final drive, and new bearings. When trying to install the chain I can add a half link and the chain will fit but it's very loose and when I hit a bump or anything the chain will fall off, if I take the half link out the chain is too tight and I can't get the master link hooked up. I counted the large sprocket and it has 54 teeth, the small sprocket has 9 teeth. Any ideas on what I'm doing wrong or what I can change to get this to fit together correctly?
Medrace
The Jackshaft won't move when moving the engine, the housing for it is welded to the base that the engine sits on.
