Manco 612 Engine replacement
brad0505
Does anyone know what I’d need to do to put a predator 212 motor on a manco 612 and what I’d need to adapt it to the belt drive?
Welcome to the forum.
Post some pics of your kart so that we know what you are working with. A few people will be able to advise you on the engine, but i am pretty sure it won't be a hard swap. The Predator is one of the most used engines on karts there in the States
brad0505
I think it is a deuce
I wouldn't go with a 212. The engine that's currently on there is right around 10hp or so. Plus the driver pulley for the CVT is a 1" bore, 212 is only a 3/4" pto. Minimum you'd want a 420 predator, to at least be close to the power rating and because that has a 1" pto on it. If I remember right, Tecumsehs are a bit odd in that the larger engines still have a smaller engine bolt pattern, but I could be wrong. You'll have more work if you drop down engine size when you're moving that much weight. I don't know what the gear ratio is of the transaxle, but I doubt it'll fully be low enough (high numerically) to compensate for a lower powered engine.
Where's it peaking oil at? Side cover or the pto seal? Both can be replaced relatively easy. If you cannot find a gasket for the side cover, go to an auto parts store and ask for a bottle of RTV that works with engine oil. If it's from the pto seal go to a small engine repair place like an ACE Hardware (they usually do small engine repair) and they might be able to order you a seal. Resealing shouldn't cost more than $50, if parts are still available. But considering Tecumseh went out of business back in 2009, I wouldn't be too hopeful at finding many parts. So a Predator 420 would be your best bet. There might be some tweaking that needs to be done, but nothing that will be too extreme.
