sawood711
So I have a Manco 285B kart with a 30 series Comet clutch. The gearing is 9 tooth sprocket beside the clutch, 54 tooth sprocket on the axle and the tires are a 18x9.5. Right now it has a top speed of about 35mph and it takes a little bit to get there, but it is slow and not that quick off the line or going up hills.
I am trying to find out what gears I would need to be have more torque off the line. I am not worried about losing top end speed since I rarely will be worried about topping out an off-road kart. I need some extra torque to get up the hills and trails I am building on my property. I have already put the spring in the third hole and it has helped a bit to go up hills, but I can tell it still has some trouble trying to make it up the hills sometimes. Any help would be greatly appreciated.
Here's a hint; 'Sid would need plane tickets to reach the western hemisphere to find a TSC.
You're just jealous that even the cheapo stuff there is better than a lot of the mid grade stuff here.....
