Main jet
thleeet
CA
Hi, I'm new to the forums. I'm 15 year old and i'm trying to modify my engine for a go kart that me and my dad are going to make. I'd like to know what does a main jet do? What difference do the sizes make? According to AGK they have sizes: 78, 80, 82, 85, 88, 90, 92, 95, 98. :huh::huh:
gvfc2
wishing i was living
Tacoma,wa
a main jet controls the fuel flow. bigger jet means more flow which means more power and runs better than stock size. someone with more knowledge will chime in and give a better explanation
The main jet is the orifice in the carburetor that meters the flow of fuel from just off idle to full throttle. Altering the size of this jet changes the mixture (air:fuel ratio). More is not necessarily better. It has to be just right in order to get full performance out of the engine. Stock size often is correct, and sometimes is just a bit small (lean mix) to meet pollution laws.
"Reading" the spark plug will indicate whether the carb is set up correctly.
