Low Profile Karting Brakes
FrancisMac
Hi all
I'm not sure if people won't like me asking this, but the karting community seems to know what's-what with dragless brakes.
I'm looking for suggestions for a hydraulic brake-caliper with return springs, but without the wideness of most of the ones on market. I'm looking for around 1500mm2 or 2.32in2 of combined piston area per caliper (I know it's on the high side for karts), and it will rarely see hard braking (if ever).
Sadly, the width is usually around 70mm from disc face to the most outer part (eg on Dent Brakes and such).
This is my diagram to try explain my needs, and the 'kart' that I'm designing for.
Thanks in advanced,
Francis.
Hello and welcome....
We typically dont see such a specific request involving that kind of math, but if you could simplify you example perhaps with examples(pics) you have seen but that need to be more of the fashion you desire... that would help...
Why not mechanical... they typically have a thin static side... routing cables can be a bit of a pain... but if not really being used....
FrancisMac
I see where you're coming from. I need something with the stopping power of Dent style brakes (4 piston, or big 2 pistons), without the hangout from oneside, perhaps with internal plumbing rather than external.
First image is the Dent Style, whilst the green ones a far slimmer version from KP (although it looks too small for my needs).
Dent also offers Front End Calipers, which don't have the hangout, but they also lack the power I need.
On the note of mechanical - I already have most of the system set up, (lines & mastercylinder).
Also while I have people's attention, does anyone recognise the red calipers?
Thanks,
Francis.
brembo calipers for motorcycle front wheels (6 or 8 pistons)
serious stopping power and rather narrow in design..
IDK what size pads they use tbh nor what limits regarding vehicle weight they have,
3200mm² per pad is possible though maybe even more
but when it comes to brakes.. brembo is the goto source IMO,
so I'd start there :D
PS another question:
why not put the disc inside the wheel? too small?
FrancisMac
Yeah I was looking at beafy motorbike calipers, do you think they'd be able to go contactless with significant retraction?
I can't put the discs in the wheels as that's where the fancy electric motors live, much to my anger.
significant retraction...
*shrugs*
whatever that means to you.
Yes they open back up once released,
if that's significant enough, only you can find out.
hub motors.. I see.. nice!
not a huge fan of unsuspended weight, but they do make sense at times.
