If you don't mind me picking your brain again really quick. I'm going to purchase some parts I just want to make sure I'm not overlooking something.Your chain looks like #35. The clutches you listed are for a much larger chain. (#41/420/40) are much larger links. Those clutches will not work with your chain or your wheel sprocket. That is why I suggested an 84 tooth on the wheel, because 12 tooth is the smallest #35 clutch I know about for a 3/4 inch engine PTO. Replace the clutch, chain and sprocket all at the same time so they break in together.
It looks like the #35 chains have more options for higher tooth sprockets. At least that's what I'm seeing through GoPowerSports site. Maybe there's another shop worth referencing as well?
The first thing is getting this sprocket in an 80 tooth option.
#35 Chain Manco Drive Sprocket
Manco Drive Sprocket #35. Go kart, mini bike & UTV parts specialists at GoPowerSports.
Combine that with this 11T clutch.
11T Centrifugal Clutch 5/8" Bore, #35
11T Centrifugal Clutch 5/8" Bore, #35. Go kart, mini bike & UTV parts specialists at GoPowerSports.
And lastly because the chain I have isn't going to be long enough I was going to get a new chain at 3 feet long, maybe 5 feet if 3 isn't not long enough.
#35 Chain, Choose Your Length | GoPowerSports
#35 Chain. Go kart, mini bike & UTV parts specialists at GoPowerSports.
I may also pick up a chain breaker to reduce the length and I might need to get a new sprocket hub as well if the one I have won't line up right.
Assuming I did everything correctly this should give me a 7.27:1 gear ratio which according to calculations should be sufficient.
Top speed looks to be around 20 mph but that's okay for this. With the wheels I have I don't think I have a ton of options outside of that.
I also want to make sure I'm not going to run into any space issues given how far the engine is from the sprocket.
