Lost compression??
Egor is troubleshooting an engine for a neighbor. He says he heard a noise and it quit running. Something about lost compression? he's going to repair it with JB weld!
I think it’s just a valve not sealing quite right. Relap and get back to me. Grab new gaskets for the side cover and head while you’re at it. Clean up the shaft as well.
BrownStainRacing
I believe you are right. It's gotta be something simple.
Could also jus be a loose nut............behind the wheel!!!!!
Justice Brothers goo ain’t gonna work this time. Muggy Weld for aluminum repairs should work real good on that though! The weld would be stronger than the case though.
  • Like
Reactions: G.W
G.W
Nyssa Oregon
Egor should try some bulk suppliers online. Does Egor know about the enternet?
No, sorry no buggy weld. Maybe you could invent it, or Egor could. Burnzomatic makes a great product also. Melts a tad under 800 degrees though.
  • Like
Reactions: G.W
