Loss of engine power
brandonros
I have a Briggs 5hp Fun Power that was running great for years and then lately has been losing a ton of power. At full throttle, it doesn't have enough power to spin the tire with a 60 lb kid in it without a push. I've completely cleaned up the carb, changed the oil, replaced spark plug, and even tore down engine and checked the valves. When I tore down, I found a strip in the cylinder that was eaten away by something. It's very small and you can barely feel it. The rings were fine so I don't know what caused it. Here's a picture but would this cause a loss of power?
http://i60.photobucket.com/albums/h28/brandonros/Mobile Uploads/20160223_084659_zpsdcamrtsh.jpg
brandonros
Ok, thanks for the tip. I bought a compression tester and checked it and its showing about 100psi so im guessing that's pretty good. It must be a clutch issue then is my guess.
brandonros
So, Fabroman, yes I've tried it on the kart since then and still not much power. I've pulled the head off since and checked the valves too and neither are stuck. I do notice that the exhaust valve opens much less than the intake but maybe that's normal. It's moving up as much as the crankshaft is pushing it. I also have a new symptom I've noticed. When running, it spits exhaust and fuel out of the carb air intake. When i put the filter on the carb, it shuts down. I've made a short youtube video of what it's doing. Any ideas?
https://youtu.be/NoVKhuO68tQ
minibikegi
Banned
sounds and looks like valve problems, that cylinder isn't good either, but yes it will run. engines always sound weird on computer, but yours has a very loppy sound ? like a valve?
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
If that was a sewing machine, It would sound Perfect.
Sorry I don't have a real answer
brandonros
Haha. Thanks. Would that be a stuck open intake valve to cause exhaust to come out of the carb intake?
Poboy kartman
Senior Moments Member
White Settlement Texas
Ummm....I actually didn't even watch your video...because I couldn't tell by listening anyway. Ya know it's just like women...you can't REALLY figure out what's wrong with them by listening!
Good luck...(but I think valves too)!
brandonros
Just going to throw it out there. Did you remove cam if so did you time it right.
No, I didn't even remove the cam. I did remove the valves and tried to clean them up with cloth and brake cleaner. The thing is, the engine was already losing alot of power and sputtering like this before I did anything. It ran great and then slowly lost a lot of power over time. Could the camshaft get bent if the engine was run too hard and cause valve issues like this? I hate to replace it if it's getting perfect compression, but I may have to.
