Looking to make an inexpensive road kart; questions
Jr. Mechanic
Waldo, Wisconsin
ANYWAYS
The pulley on the clutch is the same size as the clutch bell, if not a little bigger.
I suspect that a 4:9 ratio would burn up belts pretty darn quick.
---------- Post added at 09:47 AM ---------- Previous post was at 09:46 AM ----------
Im posting on my computer...
the pictures are on my phone...
Poboy kartman
Senior Moments Member
White Settlement Texas
That would be a 2.5:1...no way Jose.
If you have ( and I'm sure you do) a photo editor...you should shrink the picture(s) down. ( The chart of formats and sizes are at the bottom of the manage attachments page)....store them in a gallery on your computer ...then instead of trying to use links...select choose file....then select gallery...and click on the pic....then to the right...hit upload....and wait until it does..then scroll down and hit close this page...(or whatever it says.
Jr. Mechanic
Waldo, Wisconsin
Ill try that when I get home; Ill upload the pics to the computer, and go from there.
Thanks
And thanks for all of your info, too; if i still want to use that pulley setup ill have to use a jackshaft.
tinamcjittles
ello m8
Allovau
How tall are your wheels? seems like to change your ratio you need to nearly double your axle pulley diameter, or half your clutch pulley... hmm
Poboy kartman
That's why he said he'll have to use a jackshaft.
