looking for rear swing-arm suspension designs
TXST8tj
Katy, TX
I am looking for some design ideas from you guys that have built rear suspensions for your karts.
This is a high quality rendering of what I had in mind....
The long red line is the shock. The short red line is the hinge/joint that connects the lower swing arm to the chassis.
Is this something that would work...geometry-wise? It seems that I would need to do some trial and error to get the best travel out of the setup.
Another thought I had was to run the top of the shock to the backside of the chassis, and then down to the swing-arm.....instead of that bar above the engine that is shown in the pic above.
fowler
Bullsbrook West Aus
Swing arms are dead simple
It's just a frame hinged to the go kart frame that is supported by shocks
U will need to support the shock mount allot more
Take a bar from the end of the shock mount to the top of the roll bar
TXST8tj
Katy, TX
Ok. Figured it was pretty simple, just wanted to 'confirm' the basic design/setup.
The shock mount will be adequately braced.
