Looking for input on an idea I had for a transmission!
Hwasiecko
So I have a riding lawnmower with a blown out transmission and I want to turn it into a really fast go kart/buggy. The engine is perfect but a gasket blew out on the transmission and I can't reseal it. I'm not to worried about it because I don't even think it could handle the horsepower I've pushed out of this little 500cc engine. My idea is to twist a belt from the main drive shaft to a set of bike gears(I'd set them backwards so the ratio is low and I'd use the de-railers to shift the gears) After the gears I'd put a beefy motorcycle or moped cutch and lower the gear ratio more to the original differential. The goal I'm trying to get is to have a generally simple, dry transmission. I can do it but I don't know if normal little bike gears and derailers can take the heat and pressure let alone handle like 7,000 rpm. I'm pretty sure they can't so I want to come up with a good cooling system and lubrication system. Hit me with some ideas and designs if you have anything. Please no hate either because I know this is a little ridiculous but I'm just thinking out loud here. Thanks!:auto:
Hwasiecko
I have the time and the patience. I'm a little short on money but I can still buy some basic parts.
Dude, that's a signature line, a general statement not referring to anything in particular...
Did you read the thread I linked? Just in case you didn't, here's what I posted...
The one thing that will kill the cassette is torque which, incidently, will also destroy the chain...
For arguments sake, let's say that 2 stroke is 5-6hp; it will produce about 5ft/lbs of torque at around 8000rpm whereas a 4 stroke (let's say, an unmodified Predator) produces around 8.5ft/lbs of torque at around 2500rpm
You see where I'm going?
Hwasiecko
I see what your saying. I've looked at other places and I've heard different things. Some are saying that those chains and sprockets can take up to 100 pounds of torque but others say it can only take 3 to 4. I'm more on the side that it will work just because my personal expirence with is that my friend and I rebuilt his honda civic engine(I think it was the 16b) and we swapped to a timing chain and it is about as thick as a bike chain but on the other hand it could have been made of a stronger material than a bike chain is. The real problem I see is how the derailers will hold up under the stress and the heat.
But thanks guys for the input! I'm considering everything you guys say!
When I get something together I'll post some pictures and videos!
Timing chains at really different animals, and don't fall into the same category as roller chain.
And alos the timing chain move about one or two pounds of material..( camshafts)
with the counterforce of the valve springs maybe you hit 5-10 pounds max...
Nowhere CLOSE to what a kart will put to the scale.
But, this is fighting windmills...
get it, do it, try it.. then report back;
and as a word of advice: wear full safety gear approaching the running chain ;)
Hwasiecko
I'm pretty scared of having it pop on me or something but what I'm actually working in now is making a gear box the house it and then I'm going to try to fill it with some kind of oil to keep it from locking up and I'll also use the oil as a coolant by having the gears keep it circulating and I built a shroud with a fan to cool off the bottom of it
Not to be controversial again. The cassettes are lubricated with grease internally. They do not require more lubrication but equally are not easily lubricated while fully assembled, ie: they are sealed.
The chain could use some lube as it runs, I would think a dripper or sprayer would be more usefull as they typically just need a bit of oil or grease occasionally. The whole housing is good idea to contain the spray of oil/grease... Metal...
On last thing, now I'm not entirelly sure of this but it kinda has relevance, is that due to the action being submerged in oil, it may have a slowing effect(from the viscosity of the oil) on the derailers as the original design was made to function asmospherically, with out resistance. A properly setup derailer shifts excellent, but most have problems from the store and need to be adjusted(the cable tension, limit stops, cable nuts ect...).
A delay in shift could derail and cause irreparable damage.
Hwasiecko
I had the same idea. I was thinking the very bottom of the derailer like the little gear that is lower than the rest and keeps the tension in the chain would be in the oil and it would be half full or something and then maybe a little fan or wheel would hang down and spray a light gear oil on the chain and everything
