It has the same tooth count and is for a stock size chain. The only thing is im not sure on the bolt circle. Do you think it will bolt to a stock Manco drive wheel and brake drum?
Thanks for post. We need more information on your kart is what the guys are saying. make/model....same thing for the part.
Is it a manco sproket? Can you post some pics? Without any or little information to go on, all we can tell you is try it and see.
Good luck!
The most comon sprocket we sell for a #35 Chain is a 60 tooth 7-1/4" OD
a 72 tooth 8-3/4" OD, a 66 tooth, 8" OD.
More than likely you have one of those three. I am taking a wild guess, but you should.
