Long overdue
Old Kart
Canada
I finally started this frame the other night. Got about three hours into it. 24 feet of pipe at $1 a pound and a bit of bending and tacking and it's a beginning. I've had the body sitting around for about forty years so I'm trying to stay as close to the original designed cart as I can but I have only a picture and the body dimensions as a guide. I hope to have it rollin' for next spring. with any luck.
Old Kart
Canada
Nothin' wrong with being an old biker either though.:) My '92 Police Special still gets a good run pretty much everyday. Come to think of it... it's probably a good reason for me to need hearing aids too. :)
Old Kart
Canada
A bit more progress
Steering and a bit more body support. I'll trial fit the body and weld everything solid if it fits OK.
Old Kart
Canada
It's an offshore cheapy, OldBiker
I bought it at a local surplus place for 30 bucks. It works good. I had planned to use the cylinder for the scissor lift I was building but someone gave me a freebie cylinder for that and I found a hydraulic power pack to drive it.
Old Kart
Canada
A bit more effort today.
Steering setup seems to work but I'll reserve my final opinion until I've had a test drive.:worried2: About thirty degree's of steering wheel turn, from left to right so it should be snappy. I may need to shorten the front axle a bit. Wheels turn fine under the wheels wells but there's a bit of rubbing when the wheels are cranked to the extreme. I may have to sacrifice a wee bit of steering travel. Body fit pretty good but I've added a couple of supports to hold it a bit higher off the frame, only because my yard is a bit rough. Axle bolts need to be cut off too. More fun tomorrow. Thanks.
At 61 I thought thats what they were calling me, then I turned up the hearing aid, DAMM.
:roflol: Thanks for the laugh. I needed that. I nearly fell off my seat.
Your kart is coming along nicely. Good work! I look forward to seeing a vid of the kart running.
Old Kart
Canada
Thanks
I'm looking forward getting it rolling as well. I have a good 5 horse Honda for it but, to stay somewhat close to the original, I happened to notice an old B&S out in the barn that might be better. The attached pics show what I'm attempting to achieve...within reason anyway. The old engine looks very close to the original Lauson unit . Same company maybe? The Honda runs great ..decisions.. decisions . Any opinions? I can rebuild the B&S myself so no big cost concern either way.
j.concepcion54321
Rebuilding KTM, Need Kart
East Providence RI
Id just go with the honda... IT runs well and its a newer engine so itll have a little more umph if you know what i mean. Also the whole keeping it original thing is beyond my jurisdiction so if you want to, then feel free, but just remember, you dont have the original frame, the original wheels, or any other original parts besides the body.... So an extra thing like the engine thats not original wont hurt, IMO
Old Kart
Canada
That makes sense.
Thanks J.C . The Honda it is . I did a bit of research on the Lauson engine and it looked nothing like those depicted in the other carts I've seen. Lauson was bought out be Tecumseh They were B&S as far as I can tell. The Kart is for a bit of fun anyhow, and needs to be reliable enough to start when I need it too. Thanks again.
Farmer Mike
Whats the bike on the lift? I just bought a lift from a friend of mine who crashed his bike. It sucks sitting on the concrete working.
Old Kart
Canada
'92 Harley Police Special
I sure agree with you about having your work at a comfortable level. Makes things a whole lot easier.
