Bluethunder3320
- Messages
- 5,677
- Reaction score
- 2
the past week i started a full time job about 40 mins each way so ive been driving the crap out of my truck. i noticed there was grease slung all over my right front rim.
i just got aluminum rims, before that i had a completely rusted out steel rim so maybe i didnt notice the grease on it, if it has been doing this for a while.
so tonight i got some grease and pulled off the locking hub cap... which was a little loose even though the bolts were all tight. i didnt know how to take it apart past that so i just cleaned up the seal and stuck it back together.
still was a little loose.
then i took it back apart and took the splined thingy out. cleaned it, greased it, and put it all back together again. (getting the C clip back on the axle was a B****)
its still a little loose, and i tightened the allen bolts with a ratchet, if i went any more im afraid they would snap.
also i jacked up the wheel and tried rocking it back and forth, the wheel bearing has no play, but the wheel only turns about one revolution by itself before it stops. im not sure if its supposed to have this much resistance, the rear axle spins much more freely.
i can still drive it the way it is but over time it loses grease....
