live axle
squat251
ok, what is the cheapest way to aquire a 1" keyed drive shaft? I've put my trike on hold to build a friend a cart, and I would like to use a live axle, but where do i get one for cheap/ what can a take it off of to get it free?
squat251
cool, see my wife just got back from Iraq and i haven't told her about the trike, so I'm building my friend a cart (traditional 4 wheels) with the same engine, and what I'll do is put the secondary pulley onto the live axle to save time.
tell me what you guys think about this, i plan on making the frame (the "base" of it) out of 1-2" steel threaded pipe with 90* angle pieces on the corners. from there (the back of it) I'm going to put on a swing arm, and build a roll cage out of 1x1 square tubing to mount the swing arms shocks to. FYI i will be welding around the threads, as i see that to be a weak point as the pipe is thinner there.
squat251
well, its not really a torque converter, its the secondary pulley off a snowmobile engine, and I've thought about the whole oh noes loss of power cause of the lack of jackshaft gearing, but i think with the power of the engine, and the overall lightness of the cart its self, i shouldnt have any problems
Kaptain Krunch
Pro Junk Collector
vermont
Yes it will have problems. A 1:1 ratio is BAD, you wont go anywhere, i dont care how powerful the engine is, you NEED a jackshaft.
By the way, snowmobiles use torque converters, so yes it is. I hope your using the primary clutch also, if not the secondary will start to open up and then the belt will just slip.
squat251
well its a good thing that its not 1:1 then huh? the secondary on a snowmobile is rather large in comparison to the much smaller main drive, I'm pretty sure you have seen this, if not, i can post some pictures. unless my mind isnt letting me see something here, that should be around 2-3:1 not amazing, but it gets a little better
Kaptain Krunch
Pro Junk Collector
vermont
Do you know how i torque converter works? The two pulleys constantly change size, and although it may start out at 3:1 or so, at peak rpm it will be 1:1, or on some torque converters .75:1 or more.
Listen buddy, its not going to work, but if you want to be stubborn go ahead and fail, but dont tell me i didnt warn you.
squat251
okay, but at peak power, its going to be driving the drive wheel which would have broken free of the friction that held it/them in place so the 1:1 will be at peak snowmobile engine speeds, right?
hmm, but even that statement makes it less sure...it will have very little torque, i would just burn out the belt...
Kaptain Krunch
Pro Junk Collector
vermont
1:1 at sled engine peak (atleast 8k), with even 15" tires will have a calculated speed of over 400mph, and thats not realistic.
squat251
yeah, no torque to keep it up, it would jerk forward, then the main would spin burning out the belt
squat251
what tooth sprocket do you recommend for the jackshaft and the main drive shaft?
and sorry about that, ive been awake going on 72hrs so my mind is a bit frazzled
Kaptain Krunch
Pro Junk Collector
vermont
Exactly, aim for 4:1 or 5:1 gear reduction at peak rpm. So secondary on jackshaft with chain too back tire, 10 tooth sprocket on jackshaft and a 40/50 on axle
Didnt i already argue with you about this?.
squat251
its possible only it was the gearbox from the sled on that one, which so you know does work I got a chance to see it in action (and ride in seat 2) it works nicely im not sure what the ratio is though
