This is the premium chain I use. Can be gotten elsewhere for slightly less. HKK #35 Chain
or this (nickel plated): HKK #35 Nickel plated chain
Both of these chains are identical. The nickel plated just looks better and is a couple of buck$ more.
If I lift up the back and turn one wheel, the other one turns with it. If I hold one wheel in place and rotate the other one, the Sprocket on the diff starts turning faster than the wheel I'm rotating. If I hold the diff in place and rotate one wheel, the other rotates in the opposite direction.
exactly, im sorry if i was very understandable
when you said that if you hole the diff in place and turn one wheel and the other spins opposet, how easily is it to spin?
Oh, it's not too dificult, there's some resistance, but I can't help it because the whole diff isn't enclosed so there's no gear oil or anything to lubricate it. I have to grease it up every once in a while.
so most diff's do not have hardly any resistance?
bc my parents and another couple own a janitorial company and they just parted out a couple of scrubbers or somthing like that and they have diffs on them. he said if i wanted one i could have it but it hase bearly any resistance
well Mr. Kibble, i got the differential from my daad yesturday and its great!
BC it was from a parted out scrubber thingy, it had 4 pillow block bearings on there.
so i took it apart jus to look inside and the inside looks alot like yours
its got 1 beveled gear atatched to each shafts and 2 free spinning ones.
but i have a quick question about wheel hubs
Wow! That's excellent! Sorry I still haven't gotten around to showing what I did. I've been kind of busy working on some other stuff here lately, fixing other peoples cars and what not.
The way that looks set up, it should be REALLY easy to put into a project.
thank you very much
its alright, all i have is time
actually, all i realy need to know is, how much resistance if you were to jack up and turn one wheel
also, i wouldnt mind getting the gear ratio you used
me and my friend are building a 2 man go cart the width is 42" my question is how long should my axle be and how do i mount it? Also i want to put a Centrifugal Clutch on it too.
