live axle sizing
pizza1424
well thanks for the help
i got it done over the week end using some free stuff my cus got me he works for a over head door company they use one inch steel shafts got me bearings too
welded small gears to the end of the shafts thats goes to both wheels then to the cluch lil ruff on the street but off road it runs like a champ put a winck on her to case she gets stuck in mud or some thing
Kenny_McCormic
Kartless....
Michigan Troll
that kit?
most axles are 1" all 1" axle parts are labeled 1" (even though there is a slight difference) Driven sprocket sixewould depend on motor, clutch/TAV, tire sizes, and drive sprocket tooth count.
Manco wheel with 72 tooth makes almost no sense.
pizza1424
Axles + Tie Rods 13804
Go-Kart Live Axle Bearing Kit For 1in. Axle With 3 Hole Flangettes In Stock See Map 3.0 $39.99 $39.99
Brakes, Clutches, + Hubs 13807
Live Axle Sprocket Holder Hub In Stock See Map 3.0 $19.99 $39.98
Chains + Sprockets 1360
Drive Sprocket — 40 Tooth Temporarily Backordered Ships In
30 Or More Business Days* 1.0 $12.99 $25.98
Axles + Tie Rods 1387
Steel Go-Kart Axle — 36in. Length In Stock See Map 8.0 $39.99 $39.99
Chains + Sprockets 136410
Drive Chain #35 In Stock See Map 2.5 $9.99 $9.99
TotalWt(Pounds)
21.5 OrderSubtotal $155.93 CalculateShipping
*Please add additional delivery time on Backordered Items. See Map
Guaranteed Lowest Prices
these are the things i came up with the drive wheel is able to be bolted together with a 72 tooth gear like the singal drive wheel
