Poboy kartman
Senior Moments Member
Nice car. (Poboy is NOT predictable! )
If you look close the front "axle" or beam it pivots on a 5/8 bolt in the center of the frame. there are two limiters one on each side. Its basically a tractor front end.
The kart does drift now ( very well ) but only in a right hand turn which loads the drive wheel, when I turn left (at speed/sharply) the drive tire lifts up as the kart pivots and spins or looses traction. I think a live axle would fix this because both tires would be driven all the time and the lifting would not matter as much and it would not loose speed from spinning.
FYI this was a two seater I converted to center steer.
Also 1 more Question is there a bushing or something to take up the slop between the spindle and the spindle bolt?
Thanks
MrC.
Can you explain to me what the problem is, and is it like a bushing you need made? Do you have dial calipers?Im guessing my pivot kart frame is an od ball make. I could not find another one like it on the web.
I think the pivot is making the left turnning issue worse. If the frame was solid i dont think the tire would lift as much. I may pin the axle and try it before removing the pivot. I like od ball stuff.
You should see my hot rod.
MrC.
