live axle build
jimi72
Just built a live axle go kart with 145/80/6 tires/wheels a 60t axle sprocket and a 30 series torque converter with a 10t sprocket and #41 chain running a 6.5hp predator engine. Also have a 6" disc brake setup. The wheels seem to spin fine when the kart is up on jack stands but I can't seem to get enough torque to properly propel the kart on the ground. The sprocket and wheels are keyed into the axle and I am using locking collars. Any ideas? Thanks
kevbo22
Colorado
gearing is fine
its probably not the disc brake since you claim it works on jack stand
are you using a 30 series with backplate or jackshaft setup?
post some pics
jimi72
I am using a TAV 30-75 Torq-A-Verter Comet after market from gopowersports
jimi72
When I sit on the kart and press the gas pedal, the rear driven pulley spins but the chain doesn't hook up.
https://www.youtube.com/watch?v=ztZtJ68cU9Q
---------- Post added at 09:06 PM ---------- Previous post was at 08:26 PM ----------
Soon after posting this video, I figured out my lame mistake
When I assemble the TC I knew that I needed the 10T sprocket but somehow the 12T sprocket ended up on there. I went to check the extra sprocket (that I thought was a 12T) to see if there was any way possible it can go on backwards and I realized my error. Thanks for all the responses
Something is seriously wrong.... DONT CONTINUE RUNNING TILL WE FIGURE THIS OUT....
Are the TC sprocket and axle sprocket the same chain type, aswell as the chain itself is the same as the sprockets?......
It really sounds like the TC sprocket is NOT the same type as the chain/rear sprocket.... Hence the rasping of the chain....
Edit: I see we posted at the same time.....
