Linkage help with Briggs and Stratton
horsepower
I got this engine for a cheap price but I noticed that the carburetor was missing some linkages and I can't find any videos.1000001919.jpg1000001918.jpg1000001917.jpg1000001916.jpg1000001911.jpg1000001912.jpg1000001913.jpg1000001914.jpg
Are you trying to adapt it to vehicle use (minibike, go kart)? What size engine is it? It looks like a 5HP but the fuel tank looks tiny and atypical for a 5HP.
Your engine looks like it is a mixmaster of different parts. I see an older blower shroud with a newer carburetor and fuel tank, but I could be wrong. Yours appears to be missing a large oval piece of wire (shaped like a paper clip) that connects to the peg on the throttle control.
That oval piece of wire can be seen at 1:39 in this video but he has a much larger fuel tank that has the facility for a vehicle throttle assembly under the fuel tank...
Some info:
You can *bypass the governor and connect a cable directly to the throttle using the Briggs Raptor Throttle Kit. The kit is not designed for your particular rotary choke Pulsa-Jet carburetor but you can adapt it to fit. Takes a little bit of work which may or may not be worth it in 2025 where attention spans are even shorter and gumption is in short supply....😁
https://www.diygokarts.com/community/threads/3hp-briggs-throttle-linkage.41394/
Here's mine from the thread with it marked up to show how the cable is connected to the brass colored bellcrank.
Cyan: throttle cable
Yellow: clevis
Orange: cotter pin
https://www.ombwarehouse.com/briggs-throttle-kit.html
*By bypassing the governor, I mean connecting directly to the carburetor but I also mean removing the governor entirely which requires exploratory surgery (going inside the crankcase).
Got a photos of the overall engine; front, side and back? Would love to see what you have but Briggs & Stratton flathead engines are well-made, reliable and worth it, I think, to get running.
Did you ever get this fixed? You should have named the purpose. We thought it was go kart or minibike related.
There’s illustrations on page 27+ chapter 3 in this manual that shows the “paperclip". May be clear as mud but these manuals were written for high IQ mechanics. 😁
The under-tank control would be ideal because it can be vehicle control or static (set it and leave it).
