lil 3.5HP from a snow blower.
Big Daddy
In the sticks, Between Champaign/Danville IL.
Rummaging thru the barn we found the old snowblower that we no longer use. HA! Horiz shaft! Upon taking the belt shroud off we found a main drive shaft and a secondary gear driven shaft turning in the opposite direction. Is this a viable engine? Anyone ever dealt with something such as this? Certainly the secondary shaft would be doing nothing.....
Pics....
Chad
Affair_driven
BULL DETECTOR
Wolf Point, Montana
Also known as an auxiliary PTO.
It's actually an extended camshaft.
It can be ignored, cut off, or changed out.
Yes, engine is viable and will need an air cleaner.
Big Daddy
You rock, then she goes! it's for an 8 year old boy so it does not have to have killer power. I'll get the carb cleaned up/rebuilt and have something to use! I'm aware of the absence of an air cleaner and that is already probably found. Did some more digging!
We are kind of doing a "2 at once" project now :D
Raywelder
Not an Adm¡nistrator
Use the secondary shaft for an alternator or something, I wouldn't cut it off, IT may come in handy.
Affair_driven
BULL DETECTOR
Wolf Point, Montana
Possibly, but only turns half speed of crankshaft. Don't think that's enough for an alternator. With governor intact, will only spin 1800 rpm maximum.
I mentioned cutting only as an option. Sometimes they simply get in the way (clutch, TAV, etc.).
choppedandtwisted
Mosinee, WI
I picked up a nearly identical motor to yours and I am thinking about a bicycle generator to run off the Aux. pto shaft. Just a thought.
Jeff
