Lifan from Home Depot issue
supermanotorious
Winchmaster 5000
New River, AZ
now I reckon I'm pretty handy with small engines but I'm not sure what's going on here. I bought THIS engine from Home Depot and when it arrived I would almost swear it had been used
I could not tell if someone had messed with the throttle linkage but with the throttle lever at "zero" the throttle was actually wide open
there was corrosion around the gas tank cap and when I opened the case to remove the govener the residual oil looked burnt
I do not have time to return it to HD and wait for a new one
I removed the govener and adjusted the linkage to behave appropriately
It was very difficult to get it started the first time last night but once hot it idled smoothly for over an hour till I shut it down
But this morning it was difficult to start again, I had to really open the throttle to get it to start
think this is as simple as a dirty carb? Any other ideas?
I'd return it, even if it does involve waiting. You paid for new, you deserve new.
That said- did you remove the governor internals? The governor by nature holds the throtle open for starting. If you remove it, they generally start more easily if you manually hold the throttle open.
supermanotorious
Winchmaster 5000
New River, AZ
ah, I see now, I found one of my regular Predators yesterday for yet another build and noticed the throttle was wide open too, yes I do always remove the governors so that makes sense, I'll make sure to tell my customer to hold the throttle wide open while starting it
