Lifan 200cc
donman77
Legit Yah
Carberry MB
So I bought a Lifan motor from my buddy and he bought it brand new but he got trouble once he sold it to me with the idle and the engine was sputtering, and once he sold it I couldn't get it to crank up so i sent it to him and he got it to crank but he can't get it to start. He said I could get my money back if i returned it to him but i got a goo deal on it and the problem seems minor but idk, would anyone know whats up
I would check for spark. From what I've gathered, these engines have a tendency for the CDI to go bad. I'd check for spark first.
motor gauntlet
Lifan is usually a gy6 design the 200cc is a gy6 design if it's not the spark plug test the coil if the coil is not getting power check the cid if when the cid is replaced and it still will not run 9 times out of 10 it's the flywheel sensor the charging system shorting or the resistor has gone bad it if has one of its your relay is bad either way there is a lot that can go wrong with these. So here is a wiring diagram
