Let's play "Dr.Diagnosis "
firemanjim
Just kartin' around....
Houston Texas
Ok here is the deal. I've been helping a member from Illinois, with his kart problems, on a personal level via phone calls and texts messaging. I think he likes more of a one on one type instruction. We hit it off pretty good so I gave him my number for future use, in the event I'm not online or its odd hours. Past couple days we have been discussing his karts current problems. I've diagnosed 2seperate issues contributing to his karts poor performance, but I'd like to get your input... To see if my thinking is correct, and so he doesn't spend time or money un necessarily..... The follwing is a complete description of the symptoms/problems that are occurring.....
Ok, so this is a 2 seat yard kart, with 15" tires (IIRC ) in back, 13" up front. Average weight of both riders we will say is 305lbs.... (father and son) The kart is powered by an 8hp briggs engine,all stock. The fuel tank has been relocated to approximately 3feet above carb, and had a fuel pump plumbed into the the fuel system. (yes, I know what you're thinking..... )
Ok so here goes the problems..... Upon initial startup / warm up, the kart will "walk" forward, not fast, but it will creep away if you let it..... This never goes away, you must keep foot on brake or hold kart back by hand.... Once kart is up and running, it will only operate if you keep it floored. If you let off the accelerator, it will die out. It will start again after a couple pulls of the rope. It will idle/creep, but there is no part throttle operation. Only wide open or idle. Even at wot,the kart will maybe hit 7mph, with no usable power. I have to confirm the gear ratio, but I believe it's 6:1 ( maybe 7.2:1) It has a cent clutch. When it's being driven, I can see wisps of white smoke trailing very close to the engine. I can not confirm that the clutch is hotter than it should be normally,nor say it isn't. (I'm too far away :lolgoku:) I have video but without the members permission to post it, I'm trying to describe everything I see in full details. (poboy, it was a sunny day, and the grass needed a cut, but otherwise a good day/place for karting....)
Now, after talking to said DIYGK member, he removed the fuel pump and ran the tank line straight to the carb,and plugged the pulse valve. The kart still creeps forward. The performance is a little better, now maybe 15mph. It will still die when you let off the accelerator.
I am pretty sure it's 2 different things causing the problems he is having. I have told him my theory, but wanted to pass this through the forum for your 2 cents. If I can, I will post pics I have and a video or 3..... Gotta get permission first though....
So what do you guys think is going on here? :popcorn::popcorn:
too much fuel I'd say... (or too little air)
first things first:
misaligned main jet...
so all the way in, 2.5 out just to reset to default values for now.
And afterwards adjusting the idle setting again.
maybe the choke isn't operational?
Similar thing has happened to me once when I accidentally forgot to shut off the choke when the engine was warm on my 5hp flathead.
well the creeping-no power and instant dead on zero throttle thing that is..
and after restarting -to be honest NOT without wiping the plug clean in my case-
it puffed a bit of white smoke for maybe just two or three strokes;
so that kinda sounds familiar too...
Modern clone type of engine, or vintage flathead?
what carb?
maybe it's the float and/or needle; maybe the butterfly...
maybe a cracked e-tube or it's o-ring ... wait was it B&S or Tec with the O-ring on the tube, can't remember *shrugs*
anyways while checking the tube it should be obvious ;)
To provide some sort of initial idea ...
OK, first thing, we need to know what model engine/carb; being gravity fed, I think I know which carb but, need pics to confirm...
First problem, creeping at idle: Idle too high...
Second problem, only idle or WOT: there could be a number of issues:
-air filter not letting enough air through
-partially blocked main jet/e tube
-poor float level
-poor mixture setting
-air leak at carb mount
or any one or a combination of many other problems
My Advice: Run a full kit through the carb...
In my mind, at least 90% of it points directly to a carb overhaul. Yeah- like the boys above, I could point to individual bits of the carb that may or may not be a factor, but at the end of the day... Carb overhaul.
I'm on board with Tony. Sod the details, just completely overhaul the carb. By the book, rebuild to spec. Anything else will probably amount to shots in the dark. That's kinda the way I do things. If I'm going to go thru the trouble of taking a carb off, I'm just going to do the whole thing and have done with (unless it's something totally blatant like the inlet needle).
