firemanjim
Just kartin' around....
You know, you COULD replace the leaf for a single coil-over shock,adjusting it so it has enough pre-load to keep the arms resting on the "stops" (arrestors) at "idle"......
I just started reading this(not FULLY read, just skimmed the idea and possible issues).
How bout adding a coilover to the 'formula'?
A lot of this debate could be solved if every one read thru the wiki link that mckutzy posted on the previous page of this thread; it has a lot of in depth info including the how's and why's of the Corvette engineering team from when they first started developing their suspension.
PatA lot of this debate could be solved if every one read thru the wiki link that mckutzy posted on the previous page of this thread; it has a lot of in depth info including the how's and why's of the Corvette engineering team from when they first started developing their suspension.
A picture is worth a thousand words, and the wiki link has a nice handful. Just a thought.....
Pat
The difference is the Corvette spring is mounted solid to the chassis, and his appears to be only mounted to the a-arms.
I wanna see someone do a gasser style, straight axle front end on a go-kart...completely pointless on a go-kart but I still wanna see it done![]()
