lawnmower engine to go kart engine
rushking19
Richmond Virginia
For my friends go kart I am starting on the engine, I have a Briggs and Stratton lawn mower engine, right now I am in the clean up and rebuilding process, I am trying to get it to run on the side.
souperman000
Westlake Village, CA
Is it a vertical shaft? thats gonna be a pain to convert to horizontal drive. I would look up on the internet how to do it and for help. A few people on here have tried it but not to much success.
rushking19
Richmond Virginia
Here's some pictures
Brandon1023
needs an oil change
Miami, Florida, Dade County 305
They need a big sticky that says "Want to convert your vertical engine to horizontal???" and then everything should be addressed in there like the difficulty/requirements. If it was me, I'd buy a 212cc for $120. It's probably worth it avoiding the hassle and time of the conversion.
Brandon1023
needs an oil change
Dipper. And you need to fabricate a new intake manifold to reorient the carb.
And let's not forget that you'll need to find a way to change the throttle set up from fixed speed to variable speed. Unless, of course, you want the kart to begin running at 3000 RPM. Changing the throttle is going to take some planning as the majority of mowers out there (as I said) use a fixed speed throttle where a spring pulls back on the wind vane, keeping the throttle wide open. Once the wind produced by the blower reaches a certain force, the throttle is pushed ~1/2 closed or so to keep the speed limited at 3k.
You will also need to turn the tank in such a way that it's not on its side, letting all the fuel out. If the mower uses a pulsa prime carb (can't tell cuz your picture aint displaying.), you're going to have more trouble, because the carburetor must be connected to the tank for it to work, and the tank is going to need to line up just right so that the carb matches with the intake.
How do you plan on mounting the motor to the kart? You can't really use the existing bolt holes cuz they're on the same side as the output of the shaft, so this will get in the way of other things.
This is probably the least of your concerns as far as getting this thing in there, but eventually, you're going to have to change the oil. You can remove the engine and handle it like that if you want, but that's a pain in the neck in my opinion.
Also, do lawn mowers use a keyway? I fix them all day long, but I have never studied the shaft on one. If there's no keyway, you're going to have to either A. Change the crankshaft to an appropriate one. Or, B. Take it to a shop where it can be machined in to the shaft.
Sorry this is such a contradicting post lol. You just need to take a whole bunch of variables in to consideration beforehand if you want to avoid the frustration later.
