kz440
dqseve
just got my engine all wired and mounted up, was looking for some advice on a few things
1 aircleaners should i try to use the stock box or use 2 pods
2 clutch and gas cables do the stock ones work if i order a set of ebay
if any one has any answer that would be great:cheers2::cheers2:
fowler
Bullsbrook West Aus
it doesnt matter about the air filter but the pods soposedly give better performence
any cable will work as the clutch/accelorator cable
modelengineer
Lord of the noise
Sydney, Australia
I would use the stock airbox. If you want to use pods and a performance exhaust you should re-jet the carbs. It's not all that difficult but if you don't then it will run very lean.
