KZ2 Kart bogs down in LEFT TURNS
P.Car
Hey all!
Me and my friend recently bought a gokart together - A KZ2 with a TM K8 engine. We took it out on track first time today, after a couple of weeks of restoration and tweaking. Everything went surprisingly well, considering the kart is 12 years old.
The only thing that's bothering us about the kart, which we're both completely unable to understand why it's happening, is that the engine completely loses power in left turns. It doesn't stall however, it just idles.
After a couple of seconds, it springs back to life.
This happened everytime in low-speed left-hand corners, never ever turning right. In the mid-speed left turns, you could keep it from bogging down if you didn't release the throttle completely.
Apart from that, the engine itself was working flawlessly.
We're at a loss here. Me and my friend are both very new to the world of karting, so our experience won't get us very far on this strange problem. We would very much appreciate all the help we can get!
Thanks!
P
yes, carb or fuel - tank/filter/line
the only other option* would be a loose ignition rotor.. but then it should also happen in righthand turns
* (i can think of that is ;))
Joe-405
Enjoying New Projects
U.S.A.
I'm thinking a carburetor issue, float level might just be set too low.
Make sure your gas cap (or tank) is vented too.
Surprisingly a lot of people forget about the floats on shifter karts. The engines need more fuel in the bowl due to the g’s that they use during turns.
