kt100 yamaha carb setting question
spools
Ok so Im told when I run the kart to set low speed jet to 2 1/2 turns out and hi jet around 1/4 or less now I tried this the other day and the motor seems to want to start at a half turn out on low speed,now my question is that as soon as i floor it do I then turn it the 2 and a hlaf turns and just leave it alone the rest of the time or will i have to turn the low jet tighter everytime i'm not flooring it to keep from floooding?
so basically can I start it at half turn on low, hi on 1/4 turn and as soon as i take off can i then turn the low jet out 2 more turns and leave it alone the rest of the day?how do you guys do it?
mattbrown98
Queensland
i dont know but in my opinion you should just adjust the low speed to the 2 1/2 turns straight up otherwise your engine may not get enought fuel and oil until it is reved enough to get the high jet to start flowing
