boostedsr20
- Messages
- 4
- Reaction score
- 0
Hello I got a used hortsman clutch,when i fill it through the top it just slowley leaks out of the bottom,Im new to karting and clutches but the guy did send me a bag with a bunch of washers and oring,heres a pic of the clutch
now is it a o-ring I need to put internally or
do i need to place a washer and o -ring on the outside and bolt it down to the crank?If I do then I assume I need a new starter bolt since mine is straigt and wont bolt the washer/o r ing down does this sound right?perhaps theres a starter nut that will hold a washer and o ring snug enough to stop the leak or whats the deal?thank you.
