Kt100 fuel set up help
Dan93
I just bought a cart whit or kt100. Whit walbro carb my question is do I need a fuel pump or does the pulse line on the carb do the work it a race kart fuel tank is in front and is not leave so it has to run up
Dan93
PHP:
So i how do I prime the kart sorry I'm a nood at this just gettin in race kart
anderkart
Surprise Arizona USA
:iagree:
Yes, you could instal a 1/4" Marine Primer bulb between the tank & carb, but you probably won't need it if you'll be using an electric kart starter on your KT-100.
I noticed your kart is set up for the engine on the Left side, did you buy that kart somewhere in Europe or Australia by any chance?
The reason I was curious is that's common in Europe but most all single-engine racekarts in the USA have the engine on the Right side...
