what's up, does anyone knows the kohler K161 engine??
B briggy New member Messages 67 Reaction score 0 Nov 23, 2009 #1 what's up, does anyone knows the kohler K161 engine??
R Rotore Teh SPIK Messages 1,663 Reaction score 1 Location Caguas, Puerto Rico Nov 23, 2009 #2 Single cyl?
Kaptain Krunch Pro Junk Collector Messages 4,636 Reaction score 4 Location vermont Nov 23, 2009 #3 what do you need to know about it?
B briggy New member Messages 67 Reaction score 0 Nov 23, 2009 #4 yes, its a single cyl, are those enige too heavy for go kart?? can u use one of those??
R Rotore Teh SPIK Messages 1,663 Reaction score 1 Location Caguas, Puerto Rico Nov 23, 2009 #5 They can be used on a go kart. They're good engines with some nice aftermarket goodies for it.
B briggy New member Messages 67 Reaction score 0 Nov 23, 2009 #6 ok , i got one and it has been sitting for a long time, hat should i do now to get it running, take it apart and check it first?? any suggestion??
Kaptain Krunch Pro Junk Collector Messages 4,636 Reaction score 4 Location vermont Nov 23, 2009 #7 Clean the carb. There heavy, but they'll last forever if you change the oil.
B briggy New member Messages 67 Reaction score 0 Nov 23, 2009 #8 I checked everything but I got no spark...
Kaptain Krunch Pro Junk Collector Messages 4,636 Reaction score 4 Location vermont Nov 23, 2009 #9 clean points, replace if there REALLY bad.
R Rotore Teh SPIK Messages 1,663 Reaction score 1 Location Caguas, Puerto Rico Nov 23, 2009 #10 clean the points maybe you just need a new spark though.
B briggy New member Messages 67 Reaction score 0 Nov 23, 2009 #11 thnx for the help guys, i was thinking that maybe there is a kill wire or something that is causing no spark..
Kaptain Krunch Pro Junk Collector Messages 4,636 Reaction score 4 Location vermont Nov 23, 2009 #12 most likely the points if its been sitting for a while. Try a new sparkplug first though.
R Rotore Teh SPIK Messages 1,663 Reaction score 1 Location Caguas, Puerto Rico Nov 26, 2009 #13 Clean the points, new spark and maybe clean the coil and magnets on flywheel
B briggy New member Messages 67 Reaction score 0 Nov 27, 2009 #14 i think it has to do with the condenser
R Rotore Teh SPIK Messages 1,663 Reaction score 1 Location Caguas, Puerto Rico Nov 27, 2009 #15 Did you clean the coil, pionts, new sparkplug, wires and ground?
B briggy New member Messages 67 Reaction score 0 Nov 27, 2009 #16 its like the electricity is too weak to make the spark plug spark, something like that, hope you understand what i mean
R Rotore Teh SPIK Messages 1,663 Reaction score 1 Location Caguas, Puerto Rico Nov 27, 2009 #17 Yea I know do you have the right armature gap? If so then yes it could be the condenser I'll look up a way for you to test it since I forgot..
