exenos
Project Nut
Well, I just picked up a garden tractor that has a horizontal shaft opposed twin Kohler with pressure lube. Is there any thing special I should know about the opposed twins? I know they need to be kept as flat as possible.
What you need to know, is that you must give it to me. I am SO jealous! I've heard that the Kohlers are excellent engines!
I did try to roll it over by hand, but I only tried to turn the shaft and not the fly wheel. I required a lot more force than I had expected, hence the thought of a seized/rusted bearing.
@kaptain krunch
Yes, its the magnum and I hadn't originality planned on taking out the governor but after what you said I might.
