Knockoff Comet Tav2 30 keeps falling off. Help!
Dakota8800
Hello, I am new to forums and apologize in advance for any mistakes I may have made in this thread.
Now to the question, I have a Manco Eagle Phoenix II with a knockoff 30 series torque converter installed on my Predator 212. (Jet, intake and header installed) My Predator seems to idle high and shoots off as soon as the choke is turned off. Adjusting the idle screw did not help. I made sure I installed the TC correctly, yet after maybe 15-20 minutes of riding the bolt holding the driver clutch (5/16-24 X 2") Keeps coming out causing it to explode in a flurry of clutch parts. The belt is in good shape and installed with the flat end toward the engine. The bolt seems to be VERY snug when tightening and only contacts the clutch cover when washers are installed. I have bought a new 30 series driver and the same thing happened. Help is much appreciated.
Thanks for reading.
Dakota8800
Thanks for the quick reply. Isn't 2" the correct length for installing a 30 series TC? I will try teflon tape and Locktite tomorrow.
Bbqjoe
Banned
Location, Location
You can't use both.
I don't know about these knock off kits.
I just got one myself, and the driver bolt hardly even touched the shaft.
I had to find something else.
Half the time the 4 mounting bolts are different threads too.
Loctite blue...... dont forget...... you want that off to service it later..... not remain on for pretty much forever.......
supermanotorious
Winchmaster 5000
New River, AZ
For the drive unit, I use the longest bolt I can fit in the shaft, without it bottoming out, I've used Locktite in the past when I was concerned about it coming loose during engine run time and lock washers in other builds, I hand tighten the bolt as good as I can, but just like my friend Garrett, I've never had one come loose
