Kinda clueless
Otto sc
If I could get some feedback I'd really appreciate it Im new to messing around with karts I got a year dog that has 20 inch tires on back I bought a 10 tooth clutch and the lower sprocket is like 60 teeth the problem is the couch is heating up to a red hot glow I have the chain kinda tight so the kart moves when it shouldn't be now the question is do I have chain to tight and is it best to have a torque converter the engine is a predator 212
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
With 20" tall tires you should have a torque Converter.
With a 60/10 or 6:1 gear ratio your tires can only be 15" tall max.
P.S. please use puncuation. There are guys here that will not even respond when you don't.
It's just that communication by only typing, is sometimes hard enough to make a point. Remove all Punctuation and its even worse. Plus we look smarter! LOL
Welcome to the Forum
FreeRunner15
Well i sure wouldn't sit on it LOL:lolgoku:
But yeah, get either a jackshaft,sprocket with more than 60 teeth or clutch less than 9 teeth, or a torque converter. (psst..go torque converter).
What does that thing weigh anyways?
It's just THAT communication, only by typing, is sometimes hard enough to make a point.
I fixed that for you, but this sentence is still confusing.:thumbsup::lolgoku::roflol:
Edit:
Was that a demonstration sentence? It is a perfect example of how lack of punctuation makes reading difficult. I feel dumb if it was. lol
You're really going to have to gear it down. With the limited info, you'll want to run between 8:1-10:1 so you'll stop burning out clutches. 15s are the tallest you'll want to go as already said.
... and that's for single seater karts;
a second seat (and it's additional weight) makes it even worse.
I tried to figure about a combined weight of about 115kg which gave a 10.9:1. I probably should have figured closer to 145kg and that gives a 12:1 as a starting point.
His app is easier to use in metric. And a lot of the work I do has to be converted to metric. I know it sucks but in the rest of the world 115kg is 253lbs, 145kg is 320lbs.
Fwiw England uses both metric and non-SI like the US.
the app has a settings button to use lbs instead of kgs ;)
the pound is legally defined as exactly 0.45359237 kilograms
and since July 1959, when the international yard was defined as 0.9144 metres, so the inch has been exactly 25.4 mm.
So in the end, you're using metrics anyways, as soon as you try to figure out a length or weight, you're measuring a fraction of a corresponding metric value.. and metrics are sooo much nicer to calculate with, being all power of tens..
10mm to a cm, 10 cm to a dm, 10dm to a metre (== 100cm, 1000mm) 1000m to a km ...
1000 grams to a kg, 1000 kgs to a metric ton.
12" to a foot, 3 ft to a yard.. 1,760 yards to a mile... retarded rollercoaster of numbers
and dealing with fractions for everything smaller than an inch.. yeah that's so "non confusing" ...:lolgoku:
Anywhoo, the calculator can easily use inches instead of cm and pounds instead of kgs..
(it shows mph instead of km/h as well if you want)
Kinda hard to differ sarcasm over text so my fault. And I know it's easy to convert everything over and I do that for my sake because whenever I have to convert it's just easier to do it with an app than by long hand. Regardless this Kart needs a pretty low gear ratio to use those 20s or drop to 15s and then lower the gear ratio a bit just for the weight of it.
When I got to my first job out of college and they were measuring thicknesses in mils.
Thought OK, millimeters! I got this!
Wrong! Milli-Inches! US units are ok, but we need the darn prefixes that would make it easy.
i.e. kilopound, centipound, millipound....
---------- Post added at 11:37 AM ---------- Previous post was at 11:33 AM ----------
Since we are getting technical..
I find it interesting that the meter is defined by TIME!
The metre is the length of the path travelled by light in vacuum during a time interval of 1/299792458 of a second. This definition fixed the speed of light in vacuum at exactly 299792458 metres per second (≈300 000 km/s).
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
sorry,printed words on a screen ... hard to tell; so I missed that ;)
So you see my point!!! Bob
P.S. the Metric system is Dumb:roflol:
Im Kidding Please Do not respond explaining to me that America is behind the times and the entire world uses this metric system and Blah Blah Blah
