the app has a settings button to use lbs instead of kgs
the pound is
legally defined as exactly 0.45359237
kilograms
and since July 1959, when the international
yard was defined as 0.9144
metres, so the
inch has been
exactly 25.4 mm.
So in the end, you're using metrics anyways, as soon as you try to figure out a length or weight, you're measuring a fraction of a corresponding metric value.. and metrics are sooo much nicer to calculate with, being all power of tens..
10mm to a cm, 10 cm to a dm, 10dm to a metre (== 100cm, 1000mm) 1000m to a km ...
1000 grams to a kg, 1000 kgs to a metric ton.
12" to a foot, 3 ft to a yard.. 1,760 yards to a mile... retarded rollercoaster of numbers
and dealing with fractions for everything smaller than an inch.. yeah that's so "non confusing" ...
Anywhoo, the calculator can easily use inches instead of cm and pounds instead of kgs..
(it shows mph instead of km/h as well if you want)
