Killswitch
That would appear to be a SPST momentary pushbutton. I never advise using a momentary button, as you have to keep holding it until the engine completey stops, or it will restart again. In a panic situation, that could be a major problem.
Get yourself an SPST on/off toggle style switch, or latching pushbutton.
JHen
All you need is a switch like this:
and take the wire coming from the coil that connects to the block and reroute it to the switch then back to the block.
