I think I will need a relay if I am thinking about it right. The LED in the switch uses one of the positive terminals on the switch and the ground, which is the terminal on the side of the switch. So if I have the switch complete the ground to kill the engine, I will not be able to have a 12v positive wire on the switch because both of the butt terminals will be the engine ground. If I hooked up the 12v on one positive side, it would just short everything out because I have my battery grounded to the frame, and therefore the engine.
In addition, it would be backwards, so when you turn the switch on and complete the circuit, it would kill the engine, which is the opposite of what I want. So I believe that the only way to run 12v power to the switch and make it so that when the switch is ON, the engine is running, is to have a relay.
Now my other question is, if I was to have a relay, what type would I need for it to open a circuit when the switch circuit closes? It is the opposite of a lighting relay, where one closed circuit closes another. I need the switch to open the engine ground when the switch is on. Can a regular relay do that?
So it's the Robinson K894 switch (A,G,B or R is color which I don't know)?
I assume blue.. but doesn't matter.
So the switch has ground on the side (likely to use chassis ground if possible)
that's good!
Well that is, if you have the battery grounded (as one would expect) if you have it Live (connected the positive to chassis)
I hope you insulated the engine, otherwise there will be issues
So let's assume a grounded chassis..
Then one of the two terminals will be the "incomming" signal line
that should not be grounded either way... (+) labelled
the other one (D) labelled [well a symbolised headlight] Is what that (+) line will get connected to.. when the switch is in it's "ON" position
and yes unfortunately that means if you conenct the killswitch to (+) and another ground to (D) the switch will work as intended but without any light!
I'm not sure which side powers the LED, is it always on, or is it only lit when the switch is in it's ON position?
if the latter you now only need a diode (a simple single diode!)
well and a 12V line from the battery...
attach it so that the 12V cannot interfere with the KillSwitch wire
and parallel the 12V and killswitch atatched to the (+) side of things, leave (D) unconnected)
(( In case it's permalit and you can have it lit only when 'ON', attach it to the (D) side and leave (+) unconnected))
To be sure.. again a multimeter and measuring the terminals helps .
The resistive ground through the lit LED should
a) be enough to trigger the engine shutdown (needs to be verified)
b) is resistive enough to not short out (it's a resistor and a LED in between
PS I'm not sure if you even need the diode it's a safety measure in case the killswitch wire would get upset seeing a 12V signal .. so just to be sure... it's better to have one and don't need it .. right
