jonbenderr
- Messages
- 25
- Reaction score
- 0
So first of all...apologies. Searching this topic here brings up results but most lead to the idea of wiring the kill switch wire directly to the factory kill switch wiring.
While this is a reasonable solution, I feel like there should be a way the manufacturer (Yerf-Dog) intended this to be setup. I would prefer to do things this way.
Right now I'm thinking the switch on the steering column is actually bad, but I'm not sure how to test it as it only has the one wire. From searching, the yerf-dog switches are supposedly self grounding?
I've tested all the other wiring though including under the shroud and it all checks out with continuity.
In the attached image, you can see the green wire hanging down and then the black wire coming directly from the steering column kill switch (currently have the black attached at the phillips screw to keep it from dangling around). I traced the free green wire under the shroud to what I believe is a ground terminal?
So, I first assumed the black goes to green to no avail. Couldn't start the engine no matter what.
Is it a bad kill switch, or am I just being greedy thinking it would be that easy?
Any help would be greatly appreciated and again I apologize for bringing up a topic that has been covered to some extent.
