keyway in crankshaft
tlet
wisconsin
I have a 10hp tecumseh motor that I removed from a generator.
I am looking to purchase a centrifugal clutch but they all seem to require a 3/16 keyway on the crankshaft. My crankshaft is tapered to 5/8in and does not have a keyway, its smooth. Can I still use this motor for a gokart without the 3/16 keyway?
Thanks.
Russ2251
AZUSA:Powered by LAWN-BOY
Biggest concern is the taper. Generally, clutches are designed for straight keyed shafts.
Key serves to lock clutch into position so it cannot slip/spin on shaft.
tlet
wisconsin
Is it possible to change crankshaft on motor? or Any ideas how I could still use this motor? The motor runs fine. I bought an electric start generator so I thought this would be a good motor for a go kart project with my son.
porsche930dude
Upstate, NY
if it taperd down to 3/4 you could file the whole shaft down to 3/4 and dremel in a keyway. But 5/8 is too small. watch ebay for a used crank that stuff usually goes for pretty cheap
anderkart
Surprise Arizona USA
Ten-four Kaptain.
Man, someone needs to market a high quality/ inexpensive adapter to run a 3/4" or (if necessary even) a 1" clutch for all these tapered pto motors out there.
anderkart
With he cost of material and machine time would probably not be worth it.
To make only one I agree, but I'd bet theres Machine shops sittin around twiddling their thumbs that'd be tickled to knock out a run of 20, 50 or a 100... If they could immediately wholesale the lot for $20 a piece.
Then retailers like BMI, Go kart Supply or Northern Tool could meyby offer them for like $30 or so. There'd never be a huge market, but once word got around I think theres enough tapered pto motors sitting around gathering dust they'd probably end up selling quite a few.
I'd think at least some guys buying these adaptors would also be making aditional clutch/eccetera purchases they wouldnt have made otherwise. So that'd be added perk for a retailer that stocked the adaptors.
porsche930dude
Upstate, NY
the problem with making a taperd adapter is that most of the time taperd shafts vary from motor to motor. Some have steps in them or threads at the end and some only taper half way down the shaft. Theyre not all the same.
