Key Came Out of Keyway While Riding
CrunchyCupcakew
Breaker of Things
Florida
Key came out of brake drum and axle keyway. I tried blue permatex thread locker but that didn't work. What's the best method to keep keys in place?
WHATEVER YOU DO... DO NOT WELD IT ON...
A shaft collar on each side if possible... That keeps the key captive inbetween and locked to the drum/sprocket ect...
Another method is using pipe clamps either to hold onto the key itself( so the length of whatever hub, plus the width of the clamp)... Or clamps outside the hub instead of the collars.
On my bikes I have used all these methods as I had walked out keys 2 times, both I was just lucky to stop...
anickode
S.E. Michigan
One thing you can do is not to weld it on, but to put a little bead of weld down in the keyway, on either side of the key. It will act as a physical stop for the key, while still allowing you to loosen the sprocket and slide it over to remove the key.
Hose clamps work ok and are cheap/easy.
Two piece lock collars are also easy.
One piece lock collars might be best, but the hardest to install.
After two incendents involving brakes and keys(or lack there of...) I check them all in a pre trip before and after riding... Just to be sure....
My old work boots have a good flat spot on it from flintstoning it trying to stop...
Yep, I lost a wheel one time. Luckily it fell off when I was starting from a stop.
Might have be much worse if it happened at 50mph.
Key slipped out and the hub spun on the axle and fell off.
anickode
S.E. Michigan
Another thing I've seen done is the keyway filled with JB weld on either side of the key, then sanded flush. Totally removeable with a chisel down the road if you need to reposition the brake.
Hmm.. grub screws on the hub (whatever hub it is.. wheel, sprocket or -in your case- brake)
small drilled dimple on the key for the screw to locate into.
Since most hubs I know already have a grubscrew... all you need is to make a small dimple into the key most of the time ;)
CrunchyCupcakew
Breaker of Things
Florida
Unfortunately none of my hubs have grub screws. (I wish they did) Instead I've opted for anickode's J-B Weld method as I don't have a welder on hand or any welding experience/knowledge.
The only thing I don't like with the glue, is that it needs to be contained to the area of the key(and really just the end in the keyway, or it'll be a real pain if it gets on the shaft between the hub...
It's hard to get off metal and especially if things will need to be maintained and/replaced...
I, like the SS pipe clamps, no fuss no muss...
CrunchyCupcakew
Breaker of Things
Florida
I used some J-B Weld SteelStik to form stops in the keyway to keep the keys from backing out. I'll see how well it works after I get my tie rods sorted out.
