I recently repowered this cart (6.5 Predator) and have moved onto some of the chassis issues. This was a 2 seat cart that prev owner moved the pedals and steering post to a single centered position. The pedal setup isnt the best either, but just working on the chassis for now.
Rear tires are 18x9x8, fronts are 15x5x6, and the kart came with an extra set of rear turf tires in 20x10x8's. Front tires are shot, 1 front wheel is bent pretty good, along with the spindles and C brackets. Needs new tie rods, ends, etc.
Basically I need a new front end for it. Given the current configuration and need for new front tires, can I get some recommendations on setup? Should I just replace the C's and spindles similar to whats on it now or should I get a little deeper on improving the karts driveability? Appreciate your suggestions.
