Kartfab electric build
tmac
Started build June 2017.
Kartfab videos and plans really made things go well.
Controller: Kelly KLS
Battery: Sun-thing 48V 20ah
Motoer: Motenergy 907
Some pics:
tmac
Acceleration is really good........ Used 3 Speed function of Kelly Controller and 3 position key switch to put in low speed for Kiddo's.
With the controller setting set for the low AH battery, the top end speed is currently at 29 mph. Low speed is probably around 6 mph.
tmac
The area where I drive is limited to about a 250 yard stretch, go fast, slow down, turn around, go fast..... I have shuttled kids back and forth many 10's of times in a row.
tmac
The components were all sourced independently.
I consulted with Fany at Kelly Controls about this setup. Kelly Controls has provided exceptional support.
I bought KLS Controller directly from Kelly Controls.
Motor and contactor from evdrives.com
Motor Mount from ebay: http://www.ebay.com/itm/Manta-10-hp-electric-motor-MOUNT-Etek-Briggs-MT-Pattern-Permanent-Magnet-L-type
Battery from sun-ebike, (which I think is same as sunthing28 on ebay): http://www.sun-ebike.com/
The throttle sensor came from ebay. http://www.ebay.com/itm/Hall-Effect-Pull-Throttle-3-Wire-PB-6-PB-8-Curtis-Electric-GoKart-Go-Kart-Gas/
35 prog
cost of this set up
interested in the cost of this setup as listed.
Thanks Shawn
tmac
After a few months usage, this kart only is driven on dry pavement by kids. The solid rear axle makes it rather hard for kids to turn.
Is there a way I can convert to a single wheel drive while still retaining the solid axle? I thought maybe just getting a non drive wheel for the rear passenger side, but finding bearing with ID of 1" seems impossible.
Ideas?
KartFab
Dallas, TX
Get two more bearings and bearing hangars. weld on two more sections of tubing like you already did for the axle, Install bearings side by side, cut axle in half. gulp!!!
You may be able to convert it back to live axle at a future date with a 1" ID keyed collar. Just some thoughts.
Just throwin' it out there
Cut the axle in half
...add (2) pillow block bearings
...(1) on each side of the cut
...& maybe a couple of lock collers :2guns:
