I've been having some trouble getting the OE pulley off of the shaft. I've heated it up and hit it with some PB blaster a few times. My 3 jaw puller only bends the shivs. I'm probably going to cut it off or gouge it to relieve some of the tension.
The air filter was so clogged, I don't know how this thing ran with enough power to seize the chipper bearings. I've taken the bowl off of the carb once to clean out the old gas junk but one of the tubes to the venturi must be clogged because it will only run if I supply the gas/starter fluid. I've been keeping my eye out on ebay for a used atv carb but haven't found any smokin deals yet.
Scored two wheels for the rear. The tires are junk. I want to run 25x9.5 Interco Vampires on these wheels.
