kart ?
kx250kart
im building a go kart with a kx 250 2 stroke motor my ? is how would i mount the sprocket to the rear axel an it takes a 520 chain
Justin
axle with a keyway and a key and a set screw. i think thats everything, but if u cant find a 520 rear sprocket try changing the front sprocket on the engine.
basically wut freakboy said
anderkart
Surprise Arizona USA
If your able to do the machine work yourself, the least expensive option would probably be to adapt a used/smaller diamitor #520 motorcycle sprocket and hub over to your axles size.
Heres some #520 rear sprockets made for shifter karts: http://www.gokartgalaxy.com/shifter_kart_&_quarter_midget_sprockets_for_3.htm
You'd still need a kart style sprocket hub thats made to fit your axles diamitor: http://www.google.com/products?sour...a=X&oi=product_result_group&ct=title&resnum=6
More info on #520 kart sprockets here: http://www.google.com/search?hl=en&...fter+kart+sprockets&btnG=Search&aq=f&oq=&aqi=
I did some research and found some guys that recommend first changing the engine sprocket over to the #428 size for your situation, and then buying the matching chain and rear sprocket. I'm not sure why but you should probably reserch this link too: http://www.google.com/search?source...1T4DMUS_enUS221US222&q=Shifter+kart+sprockets
