Kart won't run unless partially choked
V8xjdavid
I have this engine
When I first got it all put together it was awesome. For the last few months it won't run unless I have it partially choked. This was not the case initially. My guess is/was it was not getting the correct fuel amount when the choke was off and all the way over to "fast" and I blamed bottom of the gas can gas. So I took the carb apart, cleaned everything even though it looked perfect. Added a fuel filter and flushed the fuel line. The spark plug was black, which to me indicated a rich mixture. Cleaned the plug.
But a rich mixture would mean it needed more air and that would not explain the need for the choke to be partially on.
After all this I have the same issue. Any ideas from the experts? There are zero mods to the engine other than the fuel filter and kill switch.
FlyFrog
Kankakee Illinois
I have this engine
stuck float? bad float adjustment? do you have a air/fuel screw on that engine, usally one and a half turns out is ideal, check air filter, is it clogged? are you running the right spark plug heat range?
V8xjdavid
I didn't see really any adjustment on the carb other than idle. Float moves fine. Everything inside was really clean before I cleaned it.
HBSkirmit
Intake valve may need adjustment. Not opening enough to supply the fuel to the combustion chamber
There still may be a piece of junk in the carburetor. It only takes a tiny piece to screw things up. Did you use compressed air to blow the carb all out?
V8xjdavid
I wish I could say I found some trash in the carb or some other actual fix. But...it was just me being an idiot. With the way the markings located, my dumb little brain was reading the throttle marks as choke and not the choke marks. So in reality the thing runs perfect and I am just an idiot.
It's always good to hear a happy ending to a story, even if you feel a little bit embarrassed. Plus you learned something about your engine. Have fun.
