Kart W/KX250
You were warned :lolgoku:
With the correct mount setup, it will fit, as long as you know what you're doing...
To start off, find yourself a piece of wood, plywood or sheet steel large enough & strong enough to hold the engine, clamp it to the frame & set the engine in position; then you can guage how it will fit...
voided
parking lot pimp
CT
I'm 6'4" and finally got to ride my kx125 powered shifter kart I built over the last year.. I made my mount from square stock I bought at Home Depot... Gearing was the questionable guess.. I went with 18/26 on the 11x7.10-5 tires has decent pick up and I can still clutch it and brake them loose..
Motor position and seat position are crucial.. Knowing your also gonna have a clutch and shifter some where in the mix.. Let alone right arm room for driving without hitting a motor or exhuast..
Get a seat if you don't have one and position the seat and motor for rough idea's
jturner
Do you have any pictures man i would appreciate it so much
Tig
NC
Update
I have the motor now. It took a bit longer to get due to my friend being busy with moving. The motor honestly looks to big for my frame and im not sure if it will fit. I have to do some measurements because I still need a mount what do you guys think about fitment.
Nice looking motor, its so clean.
Check the link I posted for a motor mount.
The mounts are specifically made for each motor. If you can buy it now, that would make mock up a lot easier as it would put the motor almost exactly where it needs to be.
You can fine tune everything else after the motor is in its final resting place.
voided
parking lot pimp
CT
i can email them to you. if youd like.. no matter what i do. they are coming out upside down...
Tig
NC
I'm in for updates to.
I flipped one but, for some reason it's not flipping all of them.
Nice kart voided.
