kart shut down while riding and now,,,,, nothing,,,
RACER EX
krazykartguy
West Columbia TEXAS
Gy6 150cc was running and shut off,, now turning the key does nothing,, the dash lights don't even come on!!!,, seems I can never get these two karts to run good at the same time ,, fix one the other has a problem.....smh...please help!!!
Poboy kartman
Senior Moments Member
White Settlement Texas
Given the limited info....I pretty much am going to throw some sh#! out there and see if it sticks....but...sounds like you either lost a ground......or gained one....as in something is shorted out.....disconnect any "kill" prone wires from the engine....get it running....and re-connect one at a time.....
RACER EX
krazykartguy
West Columbia TEXAS
Found the front headlight wires, disconnected and touching each other on the floorboard , that most likely caused the short ,, but when I turn the key now the dash lights don't even come on,,, what have I done!!!
Axx3d
MN
While you are going through it make sure to check each and every wire on that rig for shorts and corrosion. Just to have it done and you know what you have in the future.
