Kart parts (Funder Wheels Kart)
Show us your Funder Wheels kart. Photos help because there’s oftentimes people out there that just don’t know what they have. They may even have a donor kart but don’t know who made it.
Any particular part? I mean it’s possible you can scavenge the parts needed or play the patience game on fleabay or the like.
Pop's
I have the drive wheel, everything else i need to get it moving.
Those pioneer cabs make a better kart stand than they do speakers i see.
Looks like you need a centrifugal clutch and a sprocket and chain, or a cvt , sprocket and chain.
What size shafts are you working with?
I’ve never seen one naked like this. Knew they were cogged-belt-drive though. Look at the “Turbo Torque” bolt-on apparatus on the Briggs. That’s wild but what does it do? Wonder if the belts are available? They might be a COTS item….
I wonder if JimD knows anything about these.
Pop's
They finally got some use an 3/4 shaft, original set up is belt drive but converting too chain isn't a problem, also needing hand controls.
Do you have the steering wheel? Post more photos of the kart so’s our kart nerds can see what it needs and what can be adapted and so forth.
For the hand controls, I suspect (nearly) any motorcycle clutch and brake controls will work. What is the diameter of the steering wheel rim? If originality is not a goal, consider switching to a foot brake and accelerator. For youths, it translates well to driving and there’s way more positive control in the feet than in the hands. You can really stomp a brake pedal whereas hands get quickly fatigued.
*Added words to your thread title for maximum info
Pop's
Two levers needed aswel as the tilt steering assembly.
What does the steering wheel attachment look like on the shaft? Might be best to adapt an aftermarket “wheel” or even a similar “yoke” that will take traditional clamp on controls better than the factory part.
To wit:
Butterfly steering wheel
If all else fails, sell it for megabucks (as Funder Wheels are fairly rare) and get a real go kart. Get a Manco or a Carter Brothers or something and you will easily get it operational, either finding what generic/universal parts you need or adapting what’s unobtanium with metal glue (welding, fabricating) et cetera and drive on.
Exactly what Hellion said. Unless you are trying to restore it for nostalgic or resale purposes, sell it as parts or whole for a huge profit and buy/build something that will actually be fun to ride and modify.
