Kart newb has questions
I plan on removing that pesky governer off the predator. That will make it rev to ~5500rpm(?)
What's a good torque converter under $150? I might have to use one after all..
Thats about right
Get a Comet 30 series off ebay. The chinese equivalent or the GTC are not bad. We haven't had any real bad report about them
Scout
Nutjob
Indiana
I don't think you'll hit 5500 rpm with just the governor removed.
The clutch sprocket is part of the clutch, it won't come off.
Can you count the teeth on each sprocket and tell us what they are? I'm curious to know the final ratio, although I wouldn't be surprised to find that it is around 6:1.
Valves will float at around 5-6000rpm
95s52
No pictures to update, but last week I tied a new pull rope to the starter and gave her ****.
With a bit of starting fluid she eventually have me some signs of live but only for a brief second. I will pull the motor in the next few days. I don't want to waste time working on the old motor as I have a 212 itching to get in on the action.
Should I break in the motor stock, or should I disassemble it new and remove the governor right away?
Also, I am looking at http://www.nrracing.com/product-p/stage1hopup-p.htm anyone have anything to say about this kit? Should I get something else?
Lastly, and my biggest dilemma is to go torque converter on not? I will count the teeth on each of the sprockets along with measuring the rear wheel height to see what my ratio is. What torque converters do you guys run?
Thanks again for the comments gents!
Carb probably just needs a good clean...
Well, for starters, after yo remove the governor, you can't use the springs without a billet rod & flywheel as they will negate the valve bounce.
Also, the larger jet & hi flow air filter are useless without a hi flow exhaust...
